welland99
- Feb 26, 2009
- Location
- Malvern
- W210 E280 estate 1999 facelift; 6th gen honda accord coupe 2000
Have had problems with front and rear screen washers not working in the last couple of days which I thought must be due to freezing, but I wasn't sure because I had recently added screen wash additive.
Had a closer look tonight and first of all discovered the bottle was empty
, then found out why.
One of the front washer jets had lost its supply pipe. That was easy to replace and now it works OK again.
But the rear one is more problematic. Took ages to remove the tailgate trim, then was surprised at what I found. The water supply pipe attaches onto an elbow just behind the wiper spindle, but the elbow had a round hole in it (see attachment). Luckily I spotted a small plastic plug in the boot (miraculous how that didn't get lost when I removed the trim) which fitted into the hole. I thought (hoped) I had made a simple quick repair, but alas when pressurised with water, this plug leaks all around.
Has anybody seen this problem before? Have I lost a seal which should be held in place by the plug?
