Need massive help from you guys if possible please?
I have W210 320cdi. High pressure fuel pump started leaking. So I changed all the seals and it's fixed now. HOWEVER!! since then it's causing blue (ish) smoke. Before sorting the high pressure fuel pump it had no smoke issue at all. My question is has the rotar shaft of high pressure pump got anything to do with the timing? If so, how can I set it to the correct settings please????
Thank you.
Regards
Thank you.
Regards
