W210 vibration from 40 to 60 km/h
Danial
Spain
W210 E240 year 2000
My car is w210 320 petrol model 2000 ,,i ve a vibration problem from 40 to 60 km only in the beginning of moving every morning , after moving 12 km it is gone i ve checked all suspension parts tires rims and drive shaft line drive shift center bearing, engine and transmission mounts all r good,, unless that differential bushes I don't know if it works or not ,some told to remove it or change its shim or thickness ? If it is 4mm changed to 3 or 2 mm ...waiting ur reply ..thanks
