Hi Guys,
I'm new here, and hopefully my english isn't to bad to understand
A little bit about me: I'm David, from Germany, 22 Years old, a car mechanic and i like the W124 and everything else from Mercedes...^^ I drive a W124 E320 Estate and a W203 200K Sportcoupe
Well, i know it is possible to upgrade a W210/W202 pre-facelift to the facelift instrument cluster, with multi function steering wheel and anything else, but until now i only saw it on the V6 and 4-Cylinder models.
Now, i just want to know if it is possible to upgrade a pre-facelift W210/W202 with the M104 Engine to facelift Instrument Cluster. Do i have to change the interior wiring harness to a model with the "new" infrared key? (In german mercedes terms it's called "FBS - Fahr-Berechtigungs-System" wich is literally translated as "Access Control System") If i have to do that, i have to change everything inside the W124...but that wouldn't be bad, because i could get rid of the vacuum central locking system
So. Has anyone upgraded a pre-facelift W210 or a W202 to the facelift instrument cluster? As i said above, i know it is possible on the W202, because MBenzNL did it on a C230 K, but i do not know if it was a facelift W202 and it was a 4-Cylinder Engine...
Btw, i wrote to MBenzNL, but there never came anything back...
Many thanks in advance,
David
David
