W210 water coolant sensor
Stuart K
Sussex
E220 CDI Estate
Hi
I have a '02 E220 CDI Estate, recently the 'check water coolant' warning has randomly come on (some times a mintue after I start, other times after 30 or so minutes)
I hav checked the water levels and I keep a eye on the temperature and all appears to be fine. I'm guessing the senor has gone (this car has now done over 130K!). Question: Is this easy to replace myself (I'm not very machanically gifted)? Could any one give me some guidance?
Many thanks
Hi
Many thanks
Possibly A2105450024 - £11.63 from your local MB parts dept, best check on your chassis number though.
Easy enough to replace.
Mine has a expansion tank...
Sorry for the slow uptake, but is the sensor a scew in? Where is it.. I'm trying to take a look at the diagram..
Many thanks
it is a screw in. There is a top with 2 wires sticking out that need to come off. the it is a press in and turn left, like a pin bulb type action. it should besta on top of your tank or on top of the rad, beside the opening to pour coolant in
Yes, mine is the old model.. the W210. I thought the W211 came out in 2003. Any way, the sensor I need to replace is on the bottom of the tank I top up?
