Does a w210 steering wheel fit on a w124??
Pre facelift W210 steering wheel will fit a W124 with no problem. The airbags are the same so you can use the one of the 124. Silversaloon is correct.
The W124 "horn ring" can be unbolted from the 124 steering wheel and bolted into the new 210 wheel, as the actual steering wheel is exactly the same however the contact ring must be changed.
This also goes for R129 / W140 / R170 / W202 / early W208 wheels as stated above.
I fitted a 208 steering wheel to my 190 many years ago without problem.
