Georgem987
Happy to say it all worked as expected
Managed to set the POT around 3.7kohms for this morning on my way to work and to program Arduino to close the circuit at 1.6V MAP values... This setting would kick in between 1600-1750RPM, with no black smoke but good acceleration
Only issue i've noticed was with the MAP values hitting the 1.6V at idle which would open/close the circuit very very fast(my relay was going crazy)... Leaving work i've set the value at 1.75V which fixed the idle issue, this time kicking in around 1800-1900RPM with no smoke.
Did another run this evening with 2.7V POT value which seams to kick in even faster in the RPM range(around 1500-1600) at same MAP value of 1.75V... First pull did get a puff of smoke in the rear-view mirror(engine was half way warmed) but the next few tries did not noticed much... acceleration wise, with this setting...i would say even better
Will see again tomorrow(during day light) how it pulls and the amount of smoke it leaves behind... if it'll be too much, will raise the MAP values to 1.85/1.9V to see the results...
Only general aspect noticed was the engine temp being lower than usual(mine usually sits right under 80° line)... Anyone had the same behavior !?
