w211 200cdi oil/water leak HELP
bmwfanatic
08 200cdi
I have a 08 200cdi, and have trouble with oil and water leakage.. see the atteched picture.. The water comes from the box to the right in the picture (what is that box actually, and where can I get gasket? ? The oil leak comes from under the oil filter, it goes a hose from down under and to the box to the right..
Is it a oil cooler of some kind with pipes inside of it?
You can get a oil leak from the filter housing if the seals not changed when filter is changed & it runs down the housing.
On the left is the Egr cooler, nota commo one for leaking, check all connections & hoses are tight
hello, i have fixed the problems now, it was the oil cooler and the egr cooler.. replaced gaskets on the egr cooler, and replaced oil cooler/gasket
