After deliberating for a while and plenty of researching with all the concerns and reservations that follow, anyone after managing to source a set of 390mm Brembo floating front disks with <500miles, to include Porsche bolts and stainless spacers at a fraction of cost, took the plunge and did the upgrade and believe me no regrets as crazy stopping power and a massive upgrade over standard 360mm so anyone who has a keeper it’s an easy diy upgrade and worth the money and albeit super tight (see attached) works perfectly even with 19inch split rims. One point to note, standard Brembo pads now with harmonic balancers (I believe) did rub for some strange reason so switched to Ferrodo racing pads and perfect with no issues and now 200+ miles done the way to go and surprising responsive at slow speeds and should have been like this as standard so hole helps with others out possibly noodling on the same quandary as I did! Best to All.
