boxer 01
- Oct 23, 2009
- w211 e320cdi sport g7 with paddleshift
Well I had I had very slight leak on the transmission sump gasket, so I decided to check transmission oil level. I got the temp of sump to 45deg removed the sump plug and about 2.5 lt of oil came out. After plenty of preparation I understood that only a dribble should come out, I have looked into the sump hole and the little plastic stand pipe is still in position so why has so much oil come out, was it overfilled when it was serviced last year ? and I don't know if I should just pump this oil back in or put about a litre back in cycle through the gears and drain till a small amount is coming out. Any help would be appreciated.
