I cut mine off with a stanley knife. You only need to slice the bottom of the rubber and it comes off. It won't be needed again anyway.
I've only ever seen them in ally/silver with black rubber dots like mine. Every days a school day.....
^ They are plain rubber from the dealers.
Sports pedals have the aluminium faces which are aftermarket
Yep, yours are aftermarket too unless they started fitting them as standard on the CLS.I've only ever seen them in ally/silver with black rubber dots like mine. Every days a school day.....
can you feel a difference when trodding on them?I think they must have as my original MB CLS brochure lists under standard equipment for the CLS 55 " stainless steel pedals with rubber dots"
How did you slide the new cover on - cut bottom as well?
OP, the right way is to remove the pedal assembly, undo the pin holding the pedal at the top and slide the new cover over.
The new cover already has a cut out for the bottom.
