Any assistance on the following would be much appreciated.
Returning to to car I found the rear end fully down with the red ‘car to low’ dash warning.
Early stages of checking things through found the compressor relay Ok but no voltage at relay block terminal 2 (load supply from pre-fuse 74) dead short at terminal 8 (load supply to compressor). Suspect compressor or wiring fault and blown fuse 74 unable to confirm as yet due to poor weather and having to work outside. ⛈
However terminal 4 (relay coil voltage from controller) only shows 4.2v as my OBD reader can’t access suspension fault codes so I’m unsure of any pending codes in the controller.
Can anyone please answer the following;
is the low voltage likely to be the controller thats u/s or can this be caused by an error code?
How do you gain access to the Pre-fuse box? are the fuses a standard blade fuse and how are they removed?
Where is the controller located?. Is it possible to obtain a part number for this? Vin is WDB2112222 2006 wagon RH drive
Many thanks in advance
Chris
Chris
