The wheels should fit but the bolt holes in the W211 wheels are for M14 bolts. Your W203 uses M12 bolts.
You need M12 x 1.5 bolts with a 14mm seat radius which should be available from places like alloywheelsdirect
You could do with finding out the ET of the W211 wheels as well. Its possible you may need a spacer on the rears.
Take a look at the fitting charts for both models
Mercedes Alloys - Alloy Wheels Direct
