W211 Audio 50 APS can I fit my ipod?
SL300-24
Essex
1984 500SL, 2007 E320 CDI Sport Estate, 1995 SL320 R129, 2005 SL350 R230
How can I fit my ipod nano to enable it to be controlled via my steering wheel and plai in my '03 E320 CDI?
I have seen posts which explain the fitting with Command, but none with the audio 50.
Can anyone help please?
Regards
Ray
Regards
Ray
I have a feeling the connectors involved on the rear of the APS50 will be the same. I know that Audio20 connectors and comand are the same so why not the APS50!
Have you looked at the thread I started a day or two ago?
Miro may well be better placed to give you a definitive answer.
Thanks for that Alfie.......I have just read your post.
APS 50 does not have an AUX port ? Am I wrong ?
You need that AUX socket to make the Mercedes kit work.
The factory ipod kit, i thought slotted in between the existing connector and the comand unit. It certainly does on the A/B and c class. However the E (W211) may well be different.
Well for starters if the car doesnt have an audio gateway in the rear left you will not be slotting anything in.
I suspect that when dealing with the E class the lessons learned from A, B, C do not all apply.
MB were categorical in telling me that the iPod could not be fitted to my 2005 E280CDI, whereas they fitted it to my wife's B Class.
I agree. Having looked into it further, then I am reminded why I have nothing to do with E class comand retrofits!
Retrofits are the only thing that seperates us from BMW drivers.
look at www.audio-10.com for Mercedes Audio 10 Alpine Becker Radios and IPOD CAR KIT
please look at www.audio-10.com to get informations for use your APPLE IPOD in your Mercedes and get informations for where you can buy it for less.
Audio 50Aps
first time posting appologies if in wrong section
just got 2010 mercedes S212 with Audio 50Aps does it akcept reversing camera.
