- May 28, 2004
- Location
- Essex
- 1984 500SL, 2007 E320 CDI Sport Estate, 1995 SL320 R129, 2005 SL350 R230
I have a problem on my W211 with the Audio 50 APS. It is fitted with the 6 CD changer. I noticed when I switched off the ignition whilst playing a CD that it started to always play the radio on start up.
It also defaulted to CD 5 track 1 when you switched it to CD, instead of the last CD and track that was playing prior to switching off the ignition.
I then changed a couple of the CD’s over with the ignition off by switching the unit’s on-off switch to on.
Now it cannot find the 6 CD changer. When pressing CD, I get the message ‘CD-ROM in drive’ which refers to the Navigation disk.
I suspect that it now only recognises the single slot as the CD player. Help please! Is there a way to re-set so the unit finds the CD player? Or maybe it will re-set overnight, as this has just happened. Doe anyone know? or can you help.
