My car has been parked for a few weeks and when it has been driven after it has come up with convienience functions unavailable then they have come back after a while, then the car wouldn't start, a few hours later it did on its own with no jump cables needed.
I've replaced the battery and the car is starting but still sometimes get a battery visit workshop message although the car seems fine, sometimes it seems to idle not quite level the revs will fluctuate by 100 rpm or so.
A quick google search seems to say theres an Aux battery which might need replacing too to cure the problem?, is this common on the W211?, battery warning charge light is not staying on so I assume it's not an alternator/charging issue?, all belts look to be in place still.
Has anyone else had an aux battery fail? and know the right part number to replace it, I understand it's under the pollen filter on the right hand side of the car.
