It'll not be filling up inside the boot then running into the front buddy . The boot would be soaking if it were the case. Pour boiling water down the front drains and look for water n steam running from the wheel arches underneath.
Ah this sounds like a good idea. I will give it a go, also I did forget to mention but there is still water collecting in the boot. I put a towel below the boot lock trim to absorb some of it. bare in mind I changed all the seals and trims around the boot area 2 years ago (did a write up -> W211 Boot water leak fixed | Bodywork). Also changed tail light gaskets and boot brake light using some sealant too. Also changed both vents on either side of boot but still water getting in. Will probably renew the gaskets again and probably add some more sealant liberally.
Thanks all for your responses. much appreciated
