I removed the tail light and test individual bulb with an avometer, it seemed to be OK. I used DAS, the error code said the actuator failed. I cleared the error codes with Quick test, all problems gone?
What going on?
In the owner manual it says the tail lamp bulbs cannot be replaced individually. It pressurised and could explode if you try to change it.
