ivan1996teo
Hi all,
I have a w211 e270 cdi 2003. I had follow the below steps to enter the dyno mode but it cant successful.
1. MAKE SURE TEMP GAUGE IS SHOWING ON CLUSTER, IF NOT SELECT THE BUTTON ON THE LEFT OF THE STEERING WHEEL TO SCROLL TO THE TEMP GAUGE.
2. PUT YOUR KEY IN THE IGNITION, TURN IT ALL THE WAY OVER UNTIL ALL YOUR LIGHTS IN THE CLUSTER LIGHT UP , BUT DO NOT TURN THE CAR ON.
3. TURN THE KEY ALL THE WAY OFF, THEN BACK ON TO THE FIRST CLICK.
4. PRESS THE RESET KNOB 3 TIMES FAST IN THE UPPER LEFT OF THE GLASS INSTRUMENT CLUSTER.
5. USE YOUR UPPER ARROW ON THE LEFT SIDE OF THE STEERING WHEEL AND PRESS IT UNTIL THE CLUSTER READS ESP DYNO METER TEST.
6. SELECT THE PLUS(+) BUTTON ON THE RIGHT SIDE OF THE STEERING WHEEL AND THE CLUSTER WILL HIGHLIGHT “ON”.
7. START THE CAR UP WITH THE KEY, AND YOU ARE NOW IN DYNO MODE.
8. THE CAR WILL REMAIN IN DYNO MODE PERMANENTLY EVEN IF YOU TURN IT OFF. CHANGE IT VIA THE SAME METHOD ABOVE BACK TO NORMAL MODE.
I had tried a lot of times. When I did until No.4, it does not have anythings come out.
Do I make any mistake? Please help me guys, Thank You!
