Kevlaar
- Nov 13, 2013
- '04 W211 E220 Cdi
Hi guys,
I'm sure this subject has been done to death, but recently bought a W211, and the CD changer door won't open, the CD changer itself works absolutely fine, but the door button doesn't appear to do anything.
I've tried removing/replacing certain fuses, resetting dash factory settings which hasn't done the trick. I've also tried physically pulling the door open, which resulted in the door stuck open by about 10-20mm. Pulling certain fuses again and resetting settings allowed the door to retract back into position, so SOMETHING works.
I've seen that a few people have suggested that you remove the changer and see if the motor/gearing has been disconnected/malfunctioning, so that's my next step, however hearing absolutely nothing when pressing the door button, would suggest there's a lack of signal somewhere.
Anyone have a definite fix on this?
