W211 Centre Cluster
Vinny40
E220
On my 2005 c220 cdi My centre cluster and clock has stopped working but the rev counter , diesel gauge, temp gauage and mileage display is still working.
Then some day s the clock works for a while and then stops again.
I have checked all the fuses and all are good.
Anything else that i need to check or will disconnecting the battery for a few hours make any difference.
Also are the radios on these key coded so if i was to disconnect the battery would it knock out the radio when i go to reconnect.
Thanks in advance
