w211 clock
shawstix
2005 e270 cdi
Unable to access clock function in the instrument cluster, i have a 2005 e270 cdi with audio 20 so no command system.
All i can get from setting menu is
convenience", "instrument cluster", "lights", "vehicle
Any idea's
I don't have the manual now to look up for the exact menu sequence, but I remember that is on the first or second menu level.
You will adjust the electronic watch and after that the mechanic clock will be adjusted.
I don't have the option to adjust the clock on the audio or steering wheel:confused:
Using the steering wheel buttons navigate to the Settings menu. Access the Time and Date sub-menu to change the display settings
convenience", "instrument cluster", "lights", "vehicle is all i can access via the steering wheel options,,,,looks like it needs to go on a Star to be checked i guess
Is there an option on the Speedo that says "Navigation not available"?
If so, the car once had COMAND installed.
To get around this, disconnect battery at 11:58, reconnect at 12 as the clock resets to midday after battery removed.
I will check tomorrow,will doing the above allow clock to be changed as its an hour out as it stands
