Hi all, My COMAND system (W211 MY 2005) shuts down after between 5 to 10 minutes the system display on the HU & dash then appears to freeze with no response from the HU or steering wheel after a while the the system then switches off. The system will not switch back on unless the car has been turned off for reasonable amount of time. When working all modes work perfectly Nav, CD, DVD, radio etc. Any ideas are most welcome I suspect an item breaking down in the MOST ring. Would fitting an upgrade HU work or not and would this be an easy fit? I ask because the Nav is a bit primitive using only part post code Many thanks in advance Chris
