W211 command issues
Slacker84
U.K.
E320
Command system is booting but not completing the start-up routine.
I have checked and bypassed the nav and multi disk changer, and when I lifted the boot floor found two dead mice but no obvious damage to the module that is there, however when I try to boot this with the MOST disconnected you can see the unit sending a signal but the fibre cable coming to it clearly isn’t sending a signal.
Symptom of a faulty AGW or break in the fibre cable to this module??
mice in a car and chewed nothing......is the pope the devil....
I would be looking very carefully again.
