It sounds like it's either leaking or losing water internally or pressurising the cooling system when under sustained high load.
Slight leak from the headgasket? What colours the water and is there is there signs of leakage from the filler cap?
if this was the problem, would it be expensive to fix?
any idea's how much .. is it a big job ... ??
cheers
Does the temperature go up before the water is pushed out of the system or only after?
Strange way to operate..sorry to have given you their details in the circumstances..
some of my friends are finding it hard to accept that this car needs a head gasket .....
But i will definately go to get a second opinon from elsewhere ...
Seems to me that you might have short changed yourself.
The loss of coolant could range from a simple leak (though i think the salesman would have diagnosed and cured the problem if that was the case) to a head problem which could cost you a lot more than the £600 reduction that you negotiated on the purchase price..........
