donkmeister
- Jun 10, 2015
- 2004 E500
I have a 2004 W211. The mirror adjustment on the passenger side was not working, I suspected the usual issue of cracking wires on the hinge, and when I stripped it down that was the case.
Someone had already been in there and bodged it horrifically in the past so rather than repair, I decided to buy an "OEM-quality" mirror unit from Eurocarparts and start afresh.
On my original, there are TWO wires that connect to the mirror glass via little spade connectors, for the mirror heating. On the replacement, there are FOUR wires, ending in a small four-pin connector.
Am I correct in thinking this four-pin connector is for auto-dim feature plus heating? I.e. this is an LHD driver-side rather than an RHD passenger-side.
Can I use an adaptor or snip the wires and omit the dimming connections without upsetting the car? If so, which wires carry the power for heating?
Everything else appears to be correct with the new unit.
