W211 E 270 Cdi 2003 brakes sticking !!!!!!
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by 4life211, Sep 2, 2018.
  1. 4life211
    4life211 Active Member
    293
    Jul 14, 2015
    Car:
    mercedes 211
    Hello my friends .
    This symptoms happens when the brakes are used to much in downhills and in summer.
    So,happens when is hot outside.
    Mostly stick the front left brake.The brake pads and rotors are good .
    If anyone can advise would be great .
    Thanks in advance.
  2. GordonTarling
    GordonTarling MB Enthusiast
    1,678
    Jun 29, 2004
    Grantham
    Car:
    2007 E63 AMG V8 Estate
    The pistons are probably sticking in the calipers. Either need a good cleaning, overhaul or replacement.
  3. OP
    OP
    4life211
    293
    Jul 14, 2015
    Car:
    mercedes 211
    Thank you for replaying my friend.
    What about to syringe some oil in piston ?
  4. Smart320
    Smart320 MB Enthusiast
    2,297
    Feb 10, 2017
    Carmarthen
    Car:
    R172 SLK 55AMG , Toyota RAV4 3 dr
    maybe your life worth a quick squirt of oil, mine would require a full overhaul of the pistons, but then I am a bit particular.
    clk320x likes this.
  5. classiccarzone
    classiccarzone Active Member
    357
    Aug 1, 2012
    Ireland
    Car:
    S203 CDI estate; S204 Cdi Estate,CL 203 X 2; Daimler V8 250 X3
    Also check the caliper sliders. Very easy to check them. When they go dry they tend to stick under heavy braking before they seize totally.
  6. OP
    OP
    4life211
    293
    Jul 14, 2015
    Car:
    mercedes 211
    Thank you for repaying my friend.
    No I don't mean the life depend from oil squirt as you said ,but can't clarify what part is failing .
    Want to test one by one .
    What do you think?
  7. clk320x
    clk320x Hardcore MB Enthusiast
    10,170
    Sep 27, 2016
    United Kingdom
    Car:
    W211 E320 CDI, W212 E250 CDI, W203 C32 AMG
    Also when working on the brakes make sure you remember to disable SBC
  8. OP
    OP
    4life211
    293
    Jul 14, 2015
    Car:
    mercedes 211
    Thank you all for replaying.
    Replaced the caliper with used one and it seems working fine .
    Hope it goes well.
    Sent from my GT-I9300 using Tapatalk
  9. OP
    OP
    4life211
    293
    Jul 14, 2015
    Car:
    mercedes 211
    Hello again
    After replaced the caliper with used one ,again when it is hot outside is stuck again.
    Same symptoms.Money in trash .
    Please can anyone help me ?? I repeat that it happens only when it gets hot outside!!!
  10. OneForTheRoad
    OneForTheRoad MB Enthusiast
    2,384
    Apr 20, 2015
    uk.
    Car:
    2015 w204 c class amg sport premium +65 ford kuga 2.0 cdi zetec awd..
    caliper slide pins sticking, or sticking piston are the 2 things that it can be. strip and clean and re grease with a rubber kind grease like white lithium . other than that change the flexi hose. brakes get hot when you press the pedal metal expands when hot , the weather wont be a factor . buy a recon caliper from brakesint and be safe in the knowledge it will have all new internals and work as expected .
  11. OP
    OP
    4life211
    293
    Jul 14, 2015
    Car:
    mercedes 211
    I have replaced the caliper with used one as I said before .The used one works fine ;checked the pins and are greased with white grease as you said.Also the caliper looks fine.Now I don't know what to change next.The brake pads are almost in finish and maybe I should consider replacing them (they are cheap one).But,why this happens only on the left side and when it warms???
  12. OP
    OP
    4life211
    293
    Jul 14, 2015
    Car:
    mercedes 211
    Replaced brake hose and same problem persist .
  13. clk320x
    10,170
    Sep 27, 2016
    United Kingdom
    Car:
    Where are you based?
  14. OP
    OP
    4life211
    293
    Jul 14, 2015
    Car:
    mercedes 211
    Based in Milano at the moment.
  15. OP
    OP
    4life211
    293
    Jul 14, 2015
    Car:
    mercedes 211
    So,my friends.
    Replaced brake pads and no sticking anymore.
    The old brake pads were cheap and they can't be consumed anymore.They produce too much of heat so I think that the brake fluid expands and the SBC didn't worked correctly .
    Till now replaced caliper,brake hose (money trash ).
    I just can't understand why the problem showed only on front left tire ?
Share This Page
