W211 E220 (2002) - Transmission Question ?
Crazy Mike
Oxford, UK
E220 CDi Elegance '02
I have owned this car for nearly 20 years and have just noticed this gear selector issue. Not sure if it's normal or not !
When starting the engine, foot on brake - allows the P to move to D or R on the gear selector - fairly normal so far. When I move slowly down my drive (in D) I noticed (by accidently nudging the selector) , that I can shift between D and N without applying the brake. Going further, very slowly , it also allows me to shift between D and R without any brake pedal application.
Is this normal ? I've never tried this before but I've always thought you should need to apply the brake pedal to allow any shift.
Or is this a speed related function - What could happen if I'm motoring along and somehow the selector was moved to the R position ? It's a scary thought.
Any thoughts ?
You don't need to brake to move from D to N and back.
As for selecting Reverse, it is an electronic selector so it will not engage unless stationary.
Yes normal, I believe so you can rock the car back and forth to free it if stuck in mud/snow
As previous posts state and there will be a lock out inhibitor to prevent you selecting reverse at any real speed.
Thanks for your replies. Don't think I will be trying to engage reverse at speed .... just in case !
