W211 E220 CDI - Shifter Pops Out of 1st Gear
Discussion in 'Engine' started by LeftBrain, Sep 15, 2011.
  1. LeftBrain
    LeftBrain Member
    34
    Apr 29, 2010
    Florida, USA
    Car:
    '03 E220 CDI, '85 300TD
    2003 E220 CDI Engine OM646.961, trans 716.649 - manual shift six speed, 138k miles
    Every so often when I let out the clutch in 1st gear she pops out with a hellacious bump and of course the engine revs away. I put it back in and she takes off as normal.
    Happens more often if I'm in a hurry. Sometimes the shifter feels kinda' like putty when going into 1st, and then she usually pops out. Doesn't happen very often though, maybe once a week if I'm careful. If it feels soft (like putty) and I take it out and put it back in it clicks in nicely and works fine.
    Hasn't gotten any better or worse in 40k miles.
    Anybody ever had a similar experience that you were able to fix, and can share some advise? Where should I look first, I haven't even put it on a lift yet.
  2. OP
    OP
    LeftBrain
    LeftBrain Member
    34
    Apr 29, 2010
    Florida, USA
    Car:
    Hmmm. Guess I'm the only one this has ever happened to.
  3. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,412
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    Not many manual modern Mercedes in this country my friend!
    However that does sound like a problem in the gearbox itself.
  4. Alex Crow
    Alex Crow Active Member
    278
    Sep 30, 2011
    Super Suffolk
    Car:
    S210 320cdi
    Hello LeftBrain.
    Not sure on this one, truth is there are so few manual boxes on these that issues do not come up often.
    Guess you really need to look at that linkage and see what gives - good luck.
  5. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    It could be as simple as the engine mounts being worn or the selector linkage requiring adjustment, after that suspect a bent selector.
  6. OP
    OP
    LeftBrain
    LeftBrain Member
    34
    Apr 29, 2010
    Florida, USA
    Car:
    Thanks fellas. Hadn't thought about the engine mounts, so that's an especially good lead.
    Surprised to hear so few manual gearboxes. Over here there are *none* on the E class, so mine is special here as well.
    Will post back after I have a look - might be a while.
    Thanks! (Cheers!)
Share This Page
