axelvic
I've got an '02 W211 E270 CDi (produced in March).
I suspect that my car suffers from the Valeo radiator problem leading to glycol contamination into the ATF, at least the oil did smell a bit like antifreeze, the rpm wandered a bit between 1,200 and 2,000 rpm on light load. There was also a noticable "shudder" in the transmission when accelerating uphill.
Due to this I have replaced the radiator and flushed the transmission using approximately 18 litres of new oil.
The car runs a lot better now! The rpm only wanders slightlyaround 50 km/h on cruise control when the gearbox is cold. Should I be worried? Will it be worse before it brakes down or will it just snap, leaving me stranded?
Will I get away with just replacing the converter or is the entire transmission shot?
