Avantgarde nut
- Apr 1, 2016
- E320 Cdi
Hello all. Having recently acquired a 2003 E320cdi I have an abs problem that I am having difficulty solving. After owning it 3 weeks the dreaded ABS & ESP warning came on. I have limited knowledge but borrow my friends scanner which gave me the fault C143A speed sensor rear right check component. The local garage replaced it but it didn't solve the problem. After reading and listening to advice I replaced it again with a genuine Mercedes part as I believe the first replacement was not an original. I cleared the codes and the fault returns. Any idea where to try next as I have spent £150 on two speed sensors and still have not solved it. Thanks in advance Martin
