Welby
Hi all
Looking for some advise on this one please? Had sticking calipers on the rear, sorted that, replaced the disks (Pagid), handbrake shoes, new pads. Also had new tyres on the rear, Accelera's, the choice of the garage as his view no tyre lasts longer than any other on Mercs.
When driving around town no problem, any speed over 50mph and I get vibration, the passenger seat headrest can be seen wobbling. I had the wheels balanced 3 times, twice by the same garage, a third by another, the vibration is still there. I've tried lifting the car and spinning the rear wheels to at least determine the side but the ECU won't allow the engine to rev and gear change with or without the skid control on or off. I can't put the rears to the front as the tyre size differs. One wheel I could see had a pot hole bend on the inner rim, but not severe and I haven't hit any pot holes.
I've read about the flex disks on the prop shaft, my question is - is this likely? I read many sources about them, they do claim to cause seat vibration but they seem to be 10 years+ older cars than mine at 80,000 miles. I don't drive it hard and a visual inspection of them shows them okay even though the posts say you can't visually inspect them, they must be removed to check them thoroughly.
I drove the car through France last year and what a gem to drive at a ton, absolutely gross now, a truly horrible drive, never been so relieved to be out of it.
So disks, tyres, wheels or flex disks and not many options to narrow it down with the technology in the ECU, any help would be most appreciated.
Cheers
Cheers
