Jan 25, 2013 #1 J jon_viola Active Member Joined Apr 3, 2007 Messages 305 Location Sussex Car S212 E350 CDI Aantgarde Sport Estate Hi My 53 plate E320cdi has thrown up the following fault codes. 2047-1 rail pressure too low C16ED Any ideas as to solutions? Many thanks Jon
Jan 25, 2013 #2 BlackC55 Authorised Forum Sponsor SUPPORTER Joined Feb 8, 2007 Messages 20,604 Location Portsmouth, Hampshire. Car E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up What are the symptoms? If it doesn't start it could be a number of things. Fuel pump, Lack of fuel Injector leaking off Rail sensor faulty ETC It needs plugging in to a Star and using a guided test. I would also carry out a off test.
Jan 25, 2013 #3 OP OP J jon_viola Active Member Joined Apr 3, 2007 Messages 305 Location Sussex Car S212 E350 CDI Aantgarde Sport Estate The car drives ok. MPG is fine at around 41 if your trying or 37/8 on a M/way. The only time the check engine light comes on is when you floor it.... Thanks for your help, Appreciated!
Jan 26, 2013 #4 OP OP J jon_viola Active Member Joined Apr 3, 2007 Messages 305 Location Sussex Car S212 E350 CDI Aantgarde Sport Estate Any thoughts? Would really like to get this sorted as have a 600 mile round trip coming up.... Thanks Jon
Jan 26, 2013 #5 mersum1es MB Enthusiast Joined Aug 9, 2012 Messages 2,026 Location Finland Car W212, C219 jon_viola said: Any thoughts? Click to expand... Like above; star can perform test procedudes for single components (and perhaps more accurate fault code, if pevious was just generic code) Additions to BlackC55's list: Fuel filter, rail pressure regulator...
