Ok this is a wierd one.
I have a very aggressive vibration like my rear wheels are square.
The car only does it once in the morning i assume when stone cold after approximately the same distance from home the vibration starts (so not from the getgo) after about 1 mile.
Its not related the the engine as the car revs fine, the car also has new ish engine mounts and gearbox mount.
It does it even if i stop then cycle D, N, R, P And set off again the vibration continued.
However if I pull over turn off the car then re start and set off its gone untill then next morning.
Even after 8 hours sat in work then do a 18mile round trip after work it doesnt do it again untill the next morning.
Any ideas ?
Its a 2003 W211 E55 new box and rad and TC in 2011 due to gycol contamination so im 99% its not that.
Any ideas ?
