w211 e63 amg bumper questions
cocomillion
w211
Hello,
Im new to the Mercedes forum first time possting. I recently bought a w211 preface lift.
I been reading about the e63 amg bumper conversion from various forums.
I have some question I was hoping someone here can help with.
I seen the below on ebay, I wanted to know will this fit straight on? Or will it need some modification/ additional parts.
I read somewhere It requires “bumper Irons” (what are these?)
can I cannibalise any bits it needs from my current bumper?
Has anyone had any experience with this seller? Or these kits?
http://pages.ebay.com/link/?nav=item.view&id=131571128311&alt=web
any info greatly appriciated
The bumper isn't a straight fit. I think you need the grill and some extra fixings.
Did you notice that kit in the link is for post face lift?
Welcome to the forum
thanks for the info, what do you mean by its not a stright fit? ie do you mean the bumper it self or the grill that you mentioned? i was aware i would require a face lift grill. but not sure if i would need anything eles ie fittings etc
Sent from my SM-N910F using Tapatalk
So the list is quit extensive. Will I necessarily need all parts? I mean items I highlighted in blue could I use my existing ones? Items in orange looks like there included in the ebay item/ can I use my existing ones?
Thanks for the advice.
Apologies if some of what im saying/ asking sounds repetitive.
211-885-40-25 Bumper Cover (Cars w/headlight washers) What this?
211-880-17-05-9999 Headlamp Washer Cover
211-880-18-05-9999 Headlamp Washer Cover
211-885-10-22-9040 Tow Hook Cover Black
211-880-17-83-9040 Grill (Non Distronic) What this?
211-880-18-83-9040 Grill w/Distronic What this?
211-887-03-27 Pull For Bonnet Latch (This replaces pull on E55 bonnet latch, you do NOT need the entire E63 latch) Can I use a post facelift bonnet latch? ie are they difftent?
211-885-23-21 Chrome Trim For Bumper
211-885-24-21 Chrome Trim For Bumper
209-820-08-56 Fog Lamp
209-820-07-56 Fog Lamp
211-885-17-53 Fog Light Surround
211-885-18-53 Fog Light Surround
211-885-13-53 Center Mesh
211-880-07-03 Center Inner Plastic Support
211-880-09-03 Inner Plastic Support
211-880-10-03 Inner Plastic Support
211-885-16-37 Impact Absorber
211-885-15-37 Impact Absorber
211-885-13-37 Impact Absorber
211-520-15-22 Engine Undertray
What are these?
002-998-51-81 Retaining Clip For Mesh (Order 6)
003-994-05-45 Speed Nut For Fog Surround (Order 6)
000000-000479 Screw For Fog Surround (Order 6)
003-994-86-45 Speednut For Foglight (Order 8)
000000-000521 Screw For Foglight (Order 8)
211-885-07-16 Reinforcement For Lower Bumper (This part bonds with double sided tape to the outside of center bumper opening)
211-885-08-16 Reinforcement For Lower Bumper (This part bonds with double sided tape to the outside of center bumper opening)
Headlight washers are the little pods that pop out and squirt liquid at the lights to clean them.
Distronic is a small black shiny unit that sits behind the grille - it's active cruise control rather than the usual passive which maintains a speed.
Not sure on the rest.
hi,
yes you would need all the parts, all the bracing, supports, impact foams etc is needed, the mesh, fogs.
bonnet latch is longer on the facelift grill, grill needs to change , undertray (plastic under the engine is different.
also the parking sensor brackets need to change.
thanks guys for the info, i rekon i need to do alot more research!
