Crazy Mike
My 2002 E220 cdi has an intermittent fault where the engine management warning light comes on and the car goes into reduced revs / power / limp mode. This has happened 3 times in the last few weeks and after stopping, switching off and leaving the car for a while, it starts and runs with no problems showing. The last period between warning lights coming on was 1.5 weeks (c 200 miles). There's no other noticeable problems apart from these 3 observations.
1) The cooling temperature gauge barely reaches 50 - 60 deg (This may have been like this for a while so may be totally unrelated)
2) After a run, there is a 'rattley' type sound from underneath the car when stationary. Nudging the exhaust with a stick seems to temporarily cure it. This again may have been happening for some time. Not sure.
3) I always re-fuel at Tesco but last tank, 250 miles ago, was from a independent BP garage. May just be coincidence though.
Whilst the warning light was on with engine running, I used a Launch Creader CRP123 diagnostics and although when trying to read one of the Engine modules, it reports a communication error, the only other significant fault is C25D8 'Inspect wheel Brakes for mechanical faults'. There are a couple of other fault codes that cannot be found in the database, 1234-0000 and 1222-0000 so I don't know what these could be.
The advice is likely to be to find a Indie with Star diagnostics or take it to main MB dealer. Does anyone know a Indie with Star in the Oxfordshire area ?
Any thoughts or recommendation where a Indie with Star lurks - would be very welcome !
