Hi all
Not a regular poster but here for some help and advice. I have a E320 04 plate that has been squeaking at the front end. I knew it was suspension related and in all probability a dry bush of sorts. This weekend this has turned into a "knock" when turning the wheel and pulling away and on quick examination I now have play at the bush. Does anybody have a quick tutorial for changing the lower suspension bushes. I would also like some advice on whether it is easier to change the bush in situ (Press the bush out of the arm) or remove the arm altogether and press out on a bench. Are there any special tools needed or will the addition of heat enable me to do the job.
Any advice on the subject would be greatly appreciated
Thanks in advance
Matt.
Thanks in advance
Matt.
