W211 Headlamps
Joggreen
Herts UK
E Class W211 E320 CDi
Just a quick question, are the headlamps lenses removable on a W211 E class or are they bonded on ?
Mine look a bit misty and would like to take them of and give them a clean up.
Cheers in advance.
The Russian site doesn't show the lens as a separate item which it usually does if they are. Having said that it's not always correct.
http://www.detali.ru/cat/oem_mb2.as...GA=722.626&CT=F&cat=64U&SID=82&SGR=210&SGN=08
If you do try then good luck. The complete front bumper assembly has to come off to get at the lights. Undertrays et al.:mad:
