Hi guys,
I have an issue with my 2003 OM648 E320 CDI. Recently I havent been using the car much and I went to start it up but it just cranked and didn't start. The battery didn't appear to be the issue as it was cranking over no problem but not starting. I thought i'd try jump starting it anyway and it fired sraight up. I put the battery on charge and the car started fine the new few times. After a couple of days I had the same crank but no start issue. I assumed the battery was weak so bought a brand new AGM 017 battery and the car started straight up. The following day I started the car up, drove for approx 1 hour and then stopped off at the shops. Upon returning to the car 20 mins later, it wouldn't start again! I tried several times but the engine just cranks over and over. I disconnected the battery and left it 5 mins but still no start. Around half an hour later I managed to get a jump start and it fired straight up. I checked the battery voltage and it's around 12.75v so no issues there with the new battery. I've got STAR so I've checked it on that and there are no fault codes. I've checked a few things like MAF function, fuel rail pressure, EGR function etc but all looks fine. I don't get any warning lights and the car drives perfectly once it's started. I drove it last night and once again it wouldn't start after sitting for around 30 mins. It eventually started after a few attempts. It started up fine this monring from cold but when I got to work I tried starting it up 30 mins later and it wouldn't start. Does anyone have any ideas? I'm thinking maybe cam or crank position sensor? I've also checked for fuel leaks but there's no sign of anything.
Thanks.
Thanks.
