- Humming/droning noises, or jolting during gentle acceleration between engine speed of 1200 - 2500 rpm -
GI27.55-P-012236
Version
6
Construction Group
27.55 Transmission oil cooling
Date
01-07-2005
Validity
Model series 203 up to production date 9/2003 with M111/271/112/OM646/OM611/612.990 and automatic transmission 722.6
Model series 209 up to production date 9/2003 with M271/112/113/OM612 and automatic transmission 722.6
Model series 211 up to production date 9/2003 with M271/113/OM628/647/648 and automatic transmission 722.6
Change Reason
Addition of damage code list to be used in case of repair
Damage Code
2743104
[FONT=Tahoma, Arial, sans-serif]
Complaint [/FONT]During gentle acceleration humming/droning noises can occur in the speed range between 1200 - 2500 rpm. Likewise it cannot be ruled out that the vehicle will jolt in the rpm range stated.
The complaint can be reproduced at any time.
Cause [/FONT]The complaint can be caused by a faulty transmission control unit, a torque converter lockup clutch which has not been adapted, a fouled torque converter lockup clutch disk or by glycol in the transmission oil, see Tips documents.
Remedy [/FONT]CAUTION:
Always work through steps 1-5 in sequence:
1.) The complaint is no longer reproducible after disengaging the torque converter lockup clutch on an experimental basis. Deactivate the torque converter lockup clutch for one ignition sequence using DAS. Menu in DAS: Control units > Drive > ETC > Diagnosis routines > the torque converter lockup clutch can now be deactivated in transmission mode "W" or "C".
SSL 27287H4
2.) Only on model series 211 up to chassis end number 089500:
Check transmission control unit: AF27.10-P-9100AG
SSL 5455390
3.) Perform torque converter lockup clutch adaptation as per documentation in TIPS
SSL 27287H4
4.) Diesel particulate filter: Check whether the bracket for the diesel particulate filter is loose. If necessary tighten to the specified tightening torque.
SSL 1437038
5.) The following basic conditions must exist:
If the complaint is still present after carrying out test steps 1-4, the glycol test is to be carried out if the vehicle was produced before 9/2003, a Valeo radiator is fitted (perform visual inspection - crimping must be visible, see annex "Valeo") and the mileage is >10,000km.
SSL 2743104
Instructions for glycol test (see also annex "Glycol test"):
1. Fill 0.5 ml of transmission oil with the pipette in the small glass container (see picture 1).
2. Fill with distilled water to 5 ml (see picture 2).
3. Add a drop of "Tenside" (see picture 3).
4. Add a microspoon of "Periodic acid" and rock the small glass container (see picture 4).
5. Allow to stand for five minutes (see picture 5).
6. Add ten drops of "caustic acid solution" (see picture 6).
7. Allow to stand for three minutes (see picture 7).
8. The sample separates into two layers; an upper and a lower layer. Immerse the syringe into the lower layer and take up approx. 4 ml of the lower layer using the syringe (see picture 8).
9. Pour the fluid taken up through the filter into a clean small glass container (see picture 9).
10. Immerse test sticks in the filtered solution for approx. 2 seconds, shake and wait for one minute reaction time (see picture 10). It is essential to adhere to the timing specifications otherwise a corruption of the test results occurs.
11. Compare the color of the test sticks with the color zones on the test tubes (see picture 11).
Important: !!! Perform changed repair procedure according to the test result:!!!
- Up to 100 mg/l glycol in ATF oil: Process fault according to manual for fault diagnosis, model 211 (order number 6516 1302 00).
- As of a glycol content greater than 100 mg/l. Exchange radiator, flush torque converter, lines and transmission. see AR 27.55-P-0100A.
If the complaint is still reproducible after the flush routine, just the torque converter must additionally be replaced.
The replacement radiator must be labeled with a white mark before installation (see radiator marking picture).
