D
Deleted member 138290
Guest
So, I’ve noticed a juddering over the last couple of weeks but put it down to a slightly buckled/ repaired front wheel... had it re balanced last week and was out but still got the juddering..... I’ve noticed it seems to be after gear changes and gets worse as the gears go up ??? Would the solenoids/ electronic plate cause this ?? I’ve read up on the issues with them...... however the gear s do bang a bit so to speak when I kick down and have been like this for a few weeks...... I’ve checked the drive shaft bearings and they appear ok...... not sure about the metal bearing..... the juddering I can feel thru the footwell and from the centre console I.e gearbox ?? Any ideas or has anyone else experienced this ?? Cheers
