D
Deleted member 139109
Guest
Ive just fitted some lower control arms, the wis says do not turn the bolt and tighten the nut, the bolts are not fluted bolts, there is not enough room to tighten the nuts with a torque wrench even though the wis tells you too, how do people on hear tighten them? Can I just tighten them from the bolt end with the torque wrench instead and hold the spanner on the nut?
