Just thought I would share this.
Having changed everything on the front with lemforder parts with the exception of the strut mounts which were corteco from ECP all was fine for three months.
Then a squeak or rubber sounding grown started from what sounded like the front near side. This would sound when going over bumpy surfaces. I had a good look but found nothing. My son thought it was the rear so I used a spray silicone grease to lube every joint in turn to see if I could pin point it. No change.
Then I jacked up the front from the centre Jack point and noticed the near side strut bolt was sunk about half an inch lower than the off side. So I sprayed grease into the gap and all was good. So I got the strut mount replaced under warranty from ECP. All is good once more. I took pictures of the failed mount and the good mount.
It might help someone else when trying to find a noisy squeak.
Failed mount.
Good mount
Failed mount.
Good mount
