W211 no warm when hot outside???
4life211
mercedes 211
Hello people .
Is it normal when: in summer you open the heater inside and not warming ?
AMGeed
MB Club Veteran
Bournemouth/Poole Dorset
2014 E63 Biturbo
If you have set the temperature on the heater bezel to 20c+ you should have warm air coming from the heater vents within a mile or so.
If not, I would suspect the heater duo valve needs replacing.
What temperature is showing on the water temp gauge in the cluster once the engine is up to temperature ( a couple of miles)?
If its under 80c, suspect the thermostat. I think the new ones open at 87c
