W211 OM642 O2 sensor location - P0030
Welby
South Wales
W211 e320 cdi sport
Hi all
Under the car now and I can find only one O2 sensor on the car, is this correct? I found the downstream one at the bottom of the CAT, upstream ones can't feel or see any. Any help would be much appreciated.
Cheers
Sent from my iPad using MBClub UK
Hi all
Cheers
Yep only one that's it. Just did mine 3 days ago.
Yep, great thanks for confirming. All sorted - swapped it out with a new one, code cleared. Will check for codes in a day or so just to be sure. Just the glow plug control module now and hopefully back to full health.
Cheers
<UIImage: 0x807ebf0> size {1, 44} orientation 0 scale 2.000000
Welby said:
Yep, great thanks for confirming. All sorted - swapped it out with a new one, code cleared. Will check for codes in a day or so just to be sure. Just the glow plug control module now and hopefully back to full health. Cheers <UIImage: 0x807ebf0> size {1, 44} orientation 0 scale 2.000000
Yes I can confirm it only has 1 O2 sensor
Over a week since I've swapped the O2 sensor and what a difference, slick, sweet running and much leaner fuel air mixture ratio, much much less soot out the exhausts and never had 47mpg out of it at 75mph for 100 miles back from Birmingham last week. If you've late 30's mpg then check your codes for the same error.
Poly v belt and glow plug control module next. Cheers
Great to hear it's been a success - with the difference it makes you'd think it would be a service item - it would pay for itself in no time
