w211 passengerside doorhandle
Ronny85
W211 e270 cdi
Hello
My doorhandle is looking like this
How can i fix this problem. I had loosen the screw, and tried to push it back, but cannot, it poops out again
take a look
w211 e270 2003
The small cover on the right of the picture has to be removed to allow the handle to be removed.
It looks like something has broken inside the door as the handle itself clips into the opening mechanism and it is that which pulls the handle back in.
Have a look here:
Mercedes-Benz W211 Door Handle and Lock Cylinder Replacement (2003-2009) E320, E500, E55 | Pelican Parts DIY Maintenance Article
Ignore the part about the door lock, just pull out the small section, slide the handle towards the back and it will come out from the door.
You will need a long (250mm) Torx 20 bit to remove the screw.
Tony
Hi and thx for answer
Should i take out all my innerdoor or can i work from" outside"
It is designed so that the handle can be removed without removing any door panels.
If the mechanism that the handle sits in is broken then the inner door panel will require removing.
ok thx i willsee
