MORGANpl
- Nov 9, 2014
- Mercedes W212 E350 AMG Bluetec Night Edition Premium Plus
The brake light come on so I order full set discs and pads. Replaced front with no problem. The problem starts with the rear one. One side ok on the other one I've got problem with removing one bolt. The bolts sits in the bearing carrier I think that's how it's called that part. It goes out few mm and than gets stuck. Both parts looks made from aluminium and when you try using bit more force you have that felling like the bolt is getting soft. If more force i might brake it or damage the tread and than it will be nightmare. Anyone experience same problem? Maybe it is just the glue that is on bolt and make it more difficult? What to do? If I damage it Mercedes quote me for the part and labour 1250£
