stevieno12000
Morning guys. I have a minor issue with my w211 rear suspension level. It just seems to me to be sitting slightly higher than at the front. It raises and lowers as it should when the load area is emptied etc.
I plugged in my icarsoft scanner to check for sensor faults, none stored. The actual values state the suspension is at 6mm. Would I be correct in thinking this should be at 0mm when stationary? Under the car, the sensor looks clean and the arm free of issues.
Does this point to sensor failure even though there is no fault code? I'm a little confused, as if the sensor can read 6mm then why doesn't it send a signal to the bov to activate and lower the ride height?
Any help appreciated...
Steven.
Sent from my SM-G973F using Tapatalk
Steven.
