W211 saloon detachable towbar
estate version
okey some pic form the s211 estate witter tow bar
pic one shows drivers side bolts inside
and inside the wheel well you'll need to take out the jack holder done by renoving two 8 or 10 mm bolts
and this is the main rear sensor conection if you have parking sensors i just pulled it through the hole and uncliped it when i took off the bumper much better with two pairs of hands
okey bumper off dvd cage moved out of the way and sam unit turned arournd
when for a after market car kit from towequippe just plug and play sale on now paid about £160 including postage (dont forget to disconnect the battery ) you can see the bumper beam in the witter fitting is not needed
now the fun starts
all the nuts and bolts you need to remove are captive pointing towards the front of the car you have four bolts in the wheel well so you have to remove the steel plate and wheel well trim 5 screws and 8 plastic trim clips and pull back the trim
if you remove the heat sheilds from the sides and drop the exhaust down but only off the mounting point you can get a long ext bar and socket over the rear exhaust box ( id allready take off the rear splash cover)
bolts inside the wheel well
2nd pic towbar fitted is a beast very heavy
with electrics fitted
okey all bolts torx up to 95 nm bumper lined up to re fit
please note small hammer only ??
re fitting the bumber was fairly straight forward all in six hours including a new pair of rear mudflaps
Ironic isn't it, we did all this work to fit the tow bars and when finished you can't see them....:crazy:
Still a bit more protection if ever the car gets hit from behind with that additional metal in there.
Yes done all that work and car't see it but you know is the ready for when you need it
w211 saloon e320 oem tow bar
Hello Has anyone any fitting instructions for an OEM MERC Tow bar and OEM Electrics kit for a Jan 2008 W211 E320 SALOON
Sorry no, mine was specific to the tow bar I bought. As yours is original I would assume it fits into the distribution panel in the boot. They would make it as simple as possible for a dealer to fit but it might need setting up to recognise it has been fitted through the STAR system.
Hi.I have Mercedes e280 cdi sport 2006.I would like to fit detachable westfalia tow bar in to my car.Is the bumper in sport versin larger than normal one?Do I need to cut bumper in sport version.I know there is no cut in standard bumper.
