As part of my weekly maintenance schedule, I usually check tyre pressures. Today, one the rears was down to 25psi (from the 32psi I normally use). Suspecting a slow puncture I jacked up the car and had a quick look. Sure enough, a screwnail was embedded in the tread. The TPMS hadn't given any indication and the tyre still looked well enough inflated.
I swapped it over for the new (full-sized) spare and headed off to get the puncture repaired. About 1 mile down the road the red TPMS warning illuminated on the dash. Interestingly, it had picked up the small difference in rotational speed / circumference between the 6mm of tread on the other wheel versus the 8mm on the new spare tyre, but the pressure differential between the punctured tyre and good tyre wasn't enough to trigger the warning.
I wonder how much of a loss of pressure is required to activate the warning? Good system though, as the red warning light in the dash display is certainly an attention getter.
